P
PatrickC
Guest
" I have a problem with a '
" I have a problem with a '88 40 hp Johnson. Recently purchased a whaler w/ the engine. Previous owner hadn't used it since last summer, never had the alarm go off in the two years he owned it and never had the seperate oil tank set-up even though this a VRO unit. I did notice the nozzle off the engine next to the gas hookup. There is no oil hooked up to the VRO intake nozzle on the motor. Instead it is sealed off and I am running it with 50:1 oil/gas mix instead. I believe this is acceptable according to the service manual.
However, the alarm starts after 2-3 minutes of running. However it does not go off when engine is hooked up to hose on land and at idle. Water is flowing out, and it is cool in both cases. I have read some of you previous posts and I will check the sensor 2 wire/ 3 wire possible grounding.
Any ideas? Could the sensor be shot?
Thanks "
Thanks "
