" Joe,
This is Dennis, I e
" Joe,
This is Dennis, I emailed you on 4/6 I guess I shouldn't have sorry about that, I will post from now on.
1990 200hp Evinrude (New Rebuild)
Anyway I am still having problems with that new powerpack. Here is what I have done to troubleshoot the problem.
1. Removed all the plugs checked compression 90 psi on all cyl ( a little low considering a new rebuild don't you think )?
2. Setup spark tester with 7/16 gap, spark seems weak but does jump also intermittent spark on
#4 and #6 ( not sure how bright the spark should be )
The stator is brand new and everything ran fine with the powerpack that was damaged by National Marine, this all started when I installed the new powerpack.
Are there any problems that you know of with the CDI powerpacks I starting to think I have a defective one.
Dennis "
This is Dennis, I e
" Joe,
Dennis "
