crashkaloop
I am asking for help getting my old/new boat motor working as best it can. I have read many posts by many members, and feel Joe knows this stuff inside and out.
Here is my story:
I just bought 1989 Ranger 360v with a 1989 Johnson 175GT. Boat is in good shape, and motor started immediately when demonstrated by seller. This was done in my driveway with the water muffs on, and although I would have loved to test the rig in water, it was simply not practical, and I bought the boat anyway. The next day it was very hard starting.
We took it to a small lake to test things out, as we knew there were some electrical issues because most gauges didn't work and the wiring had been modified over the years.
After one hour of trying to start the engine, we finally succeeded. The boat ran GREAT! Idled nice, accelerated well, very fast, and started instantly every time when warm. I was grinning from ear to ear.
UNFORTUNATLY, ALL SOUTH FROM THERE.
Here are the facts as I know them now.
Compression: 95-100 in all cylinders, except one, which has 80.
VRO: I have disconnected the VRO and removed and plugged. Now running premix at 50:1 (after running the boat for two hours at 30-40 mph, no oil being used from tank)
There is leaking fuel from the Primer Solenoid from red lever. This is cracked, and I can’t find the part number for the one with the schrader valve. If someone knows where I can order one, please let me know. The valve is working fine, and after the bulb is pumped up and the key is on, pressing the key immediately shots fuel from the hose. (I only tested the one to the top carb)
The only way I can start this engine when cold is, 1) by luck, 2) using starting fluid, 3) switching the lever from auto to manual, then back to auto after engine starts.
The reason I am asking for Joe’s help is, I thought sticking with one set of methods, and one clearly knowledgeable individual, might prove to be a good exercise for not only myself, but others who might have similar problems.
Although there are other problems, I will wait until Joe ask me questions before I mention those.
If Joe is reading this, the gauntlet has been thrown down. I promise I will do whatever you instruct me to, in the exact manner you ask me to. I will not complain or argue, but I may ask questions so that I can understand better. The one thing I won't do is take it to a mechanic, as the whole purpose for me is to learn everything I can about the engine.
I want to go from whatever I have now, to a perfectly running engine that starts and runs great. Dependable and trustworthy, just like Joe. (that was just to butter him up)
Thanks, and I sure hope Joe responds.
Here is my story:
