P
Pete Hall
Guest
" I have a 1956 Johnson RDE18E
" I have a 1956 Johnson RDE18E 30hp that was originally equipped with a 6v battery and 3 pole starter solenoid (#277317). I was fortunate enough to find an original, still in the box, solenoid for this motor, but would like to run a 12v battery. I have been told different things: simply change out the battery and it will work fine and/or I need to change out the solenoid too. I have a 10th edition Johnson Service Manual which includes the RD series and it recommends changing the battery to a 12v from the original 6v and does not mention anything about having to change the solenoid. My question is: Is it really that simple? Can I simply change the battery to a 12v without having to change the solenoid? It has been my thought that a solenoid designed for a 6v system will do fine with a 12v battery. Is this correct? I would appreciate your thoughts on this. Thanks. "
