trollingbob
" Joe; I started to install th
" Joe; I started to install the charge kit 174037 you said was needed for my motor and everything went fine until I came to the the rectifier, for some reason I can not find two holes that line up to install said rectifier much less the terminal block the OMC directions are good but the pictures are not, probably an older motor in there illastrations? At any rate this is a bad thing because I have someone comeing to fish this Friday any help you could provide will be much appriceated. "
