P
PAUL CASTEEL
Guest
" Joe,
I'm still waiti
" Joe,
I'm still waiting on the manual but, I had a few questions. The small lines that you spoke of are they the two lines that run to the carbs? My motor has the large line that runs to the bottom of the box that the solenoid is attached. There is one small line (1/8") that runs down to a white screw in unit with two wires out of the front. The box has two (3/8") lines that run to the fuel rail on each side of the carbs. There is one vent line on top of this box that runs to the air cleaner. I think that I pulled the wrong one being the 1/8" line running to the white valve. I had the primer bulb pumped up and when I released this one fuel flowed out of it. When I checked the primer bulb and pumped it it sprayed fuel. I take it that maybe I should have removed the fuel lines from the carb manifolds. Thanks again. I will keep you informed.
Paul "
I'm still waiti
" Joe,
Paul "
