Jim L
luckyjim17
I have a 50 HP Yamaha 4 stroke. How can I determine the output of the charging system from the engine? It may be that I have a bad battery (dual batteries) as I do not get but 12.25 volts on the batteries at idle. Can I check the charge directly on the engine?
put the hand held volt meter on batt
turn to a/c volts
start motor
rev up to around 1500 rpm
if reads over .7 a/c volts = bad voltage regulator
