What are the compression numbers? Did you surface the carb flanges and install new gaskets? Did you pull the soft plugs (welsh plugs) on the carbs when you rebuilt them? Are the carbs opening at exactly the same time? Is the tach still connected? If it is not working disconnect it to take it out of the loop until you can get a new one. Sounds like your close and missing something simple just keep at it. I do one thing at a time so you know where the problem was. Have you done a cylinder drop test? While idleing pul a plug wire and quickly put it back on the engine should respond the same on all three wires.
If I remember correctly, the compression numbers were around 112psi(that being the highest) and the rest were within 5psi. I didn't surface the carb flanges, but I did install new gaskets. I did pull the Welch plugs and when I installed the new ones, I put some nail polish on them. I did spray some starting fluid around the carbs while running to see if the idle changed, I didn't notice any change. The tach is still connected. I have not done a cylinder drop test...I'll have to try that next. Is there a good way to pull a plug wire without getting zapped?![]()
