PleasantBoater
I took the lower unit off for 2 reasons 1. There was water in the lower unit 2. The remote control would not shift into forward. (It will do reverse)
The flywheel does rotate
The remote control will shift into forward with the lower unit off
With the lower unit off, the shift rod will shift into reverse, neutral, and forward but it won't stay in forward. It pops back down into neutral. Is this normal? Could the problem be something other than parts in the lower unit?
Right now I plan to take apart the water pump, propeller shaft assembly, take out the drive shaft to look for damage and replace seals and any other parts that are damaged and then reassemble. I do have a manual.
