Gazza265
Me again,
I am told reliably by those in the know on here that making the 6hp into an 8hp is not an economical nor for that matter even worth the trouble.
So, to those much clued in gentle people here who harbor massive amounts of knowledge and wisdom I have another little gem of a question to pose to you:
I have measured the Carby ( 325312) base venturi hole and it is 20.5mm or .807" in diameter, I then used my trusty Mitutoyo Vernier Caliper to ascertain that the inlet hole in the Inlet Manifold measures a mere 16.0mm or .629in. Now this raises a question in my curious mind, would using a Dremel tool to port match the carby and inlet manifold be a wise move or not?
If not, can someone explain why?
