J150 Lower Unit OIl
seahuntdave
"Having recently purchased thi
"Having recently purchased this engine, I decided to change the lower unit oil. To my surprise, it was green color. I assume this is synthetic?
I replaced it with conventional high quality lower unit.
Is the green oil synthetic. Is it so much better to warrant going back to? Is there a problem changing back and forth? (residual mixing)
1998 J150 EXECD (25" extra long shaft)
Thanks,
Dave"
"synthetic,is supposed to be b
"synthetic,is supposed to be better oil for lots of reasons.....we use sierras premium gear lube at my shop...,on a new,high HP eng,i would use synthetic.
not a prob,going back and forth."
"If you change the lower unit
"If you change the lower unit oil once a year or every 100 hours of run time (whichever comes first), I don't really see a need to spend the extra money for sythetic.
Just pick an oil that is GL-5 rated and all should be fine.
Green oil? could be a sythetic - or maybe it was just moldy
"Yes, it is green- but it is c
"Yes, it is green- but it is clean and clear. Glad to know I did not mess up using conventional oil.
The inexpensive pump and hose kit that screws onto quart oil bottles makes it so much easier to do a lower unit oil check or change. Don't want to go back to squeezing that plastic tube.
Thanks to all-
Dave"
