J150 1994 no spark
jonesg
"Hi , I've been reading fo
"Hi , I've been reading for weeks but registered to post my question.
Johnson 150 , 1994 J150WCLERS , commercial.
runs rough throughout range. Idles decent but won't rev smooth.
Compression is even, I rebuilt all carbs, new tank , bulb, lines etc, new battery.
Fresh fuel, running VRO system, everything works.
Spark test showed the starboard bank all bright blue spark with good snap.
Port sparkplugs cannot fire 7/16th gap.
They do fire if the gap is reduced to 1/4 inch.
Shift assist switch tests ok.
Timing light shows spark throughout rev range , doesn't look to be dropping a spark anywhere.
Obviously spark quality isn't good enough.
I can't imagine the odds of 3 coils going bad at the same time on one side only and I suspect the power pack at this point. IS my thinking correct on this?"
"The coils are twin packs, 2 c
"The coils are twin packs, 2 coils (side by side) in one unit, you can swap em up and down but not side to side.
Swapping up and down wouldn't show anything because they'll all weak on the port side.
I don't think the primary (small) wires will reach to swap sides for a sparkplug removed test, but its an idea to try I guess.
Yeh, actually I think you gave me a decent idea."
