mstahl1171
My neighbor just purchased a "Gently" used Grady White CC with a Johny 140hp J140TXESE. We went for a test run yesterday and could not get the motor over 4000 rpms. Motor ran fine other than that. I noticed after we returned that the prop was a 15x17 on a 15 spline shaft. Maybe I am wrong but I thought the V4 motors were 13 spline shafts. Anyways...We did the the 3 turn flywheel method to determine that the gear case is from a V6 - 1.85:1. Here is the link for the test procedure: http://www.evinrudenation.com/owner...ination-and-speed-calculations-for-your-boat/.
I could not find any parts listings for a V6 gear case on a V4 motor. Am I wrong?? Should he just change the prop to a 15x15 or change the gear case? My concern is that the larger prop and gear case will put too much strain on the motor and bearings.
He ordered a service manual yesterday. Maybe that will shed some light.
Mark
Mark
