J115GLEDR
Bocaj
Good morning all
I recently purchased a boat with this engine. It's a 1996 model. 3rd owner but second owner was my father for the past 4 years.
Anyways over this past winter I did a couple of things to the engine to help prevent possible breakdown at my local lake
1. Rebuilt fuel pump. Oil side has been deleted for some time. We run a 50:1 premix. I did this because the engine would not stay running after approximately 2 minutes and would only stay running after hitting the primer bulb. This corrected that issue.
2. Replaced all for plugs just because. Can't remember the gap that it called for but remember checking from what I read online. Yes I went back with champions.
3. Replaced both thermostats with OEM due to what looked like scale build up and I thought why not? Best to keep this rascal from overheating.
4. Replaced gear oil in lower unit.
5. Tachometer hasn't worked the past 2 years. Dad said he did some kind of check he read online but couldn't remember what that was. Anyways I hadn't gotten around to fixing or diagnosing this issue.
So that's the history of this engine to my knowledge.
Went out yesterday with some buddies for some fishing. Didn't run it hard as it was my maiden voyage with this rig. Ran great and the highest speed I got to was 20 mph. While heading back to the ramp about 1/2 mile away the engine started vibrating to beat all hell. I immediately killed it. No warning lights! Pulled cover nothing caught my eye. Tilted up to look at the prop best I could and nothing stood out.
Anyways started back up at idle and engine sounded ok to my untrained ear. Could give her a little throttle and she would move but once you gave it any decent amount she would vibrate. Again no alarms and she was pissing water out which told me water pump and stats were working. We could however smell gas while at idle.
ONE thing that stood out to me was how hard the boat would pull to the right the little bit I did run it getting back to the ramp. Almost leads me to believe I lost a cylinder.
Got it home and decided to check my plug wires with my Lisle in line spark checker. And the bottom left cylinder I had a hard time seeing the spark in the glass as opposed to the others. So I ordered new wires, coils and just went ahead and ordered the powerpack for good measure.
With all of this being said any advice or thoughts that y'all can offer is appreciated.
Did you replace the water pump impeller ?----Checked gear oil / magnet on the drain plug?------Did you fill gear oil from the bottom till it came out the top ?----I do not use a fancy " light " spark checker.-----Use an open air tester with 3/8" gap.-----Not sure why anyone would buy a new powerpack and 4 new coils without some resting / old time trouble shooting.
Racerone
If you read under No. 4 you'll notice that the lower unit oil was changed and done by all suggestions that I have read on this site. Yes to the top with the manufacturer recommended gear oil. Also there was minimal fragments on the magnet.
You should try the fancy tester my good man. Yes it's not old school but has proven very effective. Lisle version who manufactures for all major tool companies is $17 from O'Reilly's.
To answer your question as to why anyone order all those components. All look to be original to the engine which is almost 30 years old. Also in my experience with the spark tester on any engine (car/motorcycle) what have you.....the inline spark tester glows much brighter than what I observed.
The water pump impeller has not been replaced as the stream coming out is very strong and was going to be a project of mine this coming winter.
Racerone
Not sure what I said to illicit this response but ok......I answered your questions professionally and only made a suggestion about you trying a inline spark tester.
Good luck to you as well sir.
I have a number of these 60 degree motors for parts / rebuild.----Repaired motors since 1968.----Sometimes my help is not appreciated !
Ahhhhh......but you did not offer any help or guidance. You asked questions that were already present in the initial post. Then ridiculed about not proper diagnosis.
If you want to give someone the get off my lawn crap take it somewhere else.
If you want prove how GOOD you think you are then how about a helpful suggestion about what you might think the issue could possibly be. This is how the Internet/forum community is supposed to work.
