Hello,
I recently purchased a 1996 Evinrude 4 hp (model E4REDS), and I'm having some problems that I was hoping you folks could help with. The motor starts and idles fine, but when I put it in gear and open the throttle it will run fine for a few seconds before it bogs and dies. If I pull out the choke about 1/3 of the way, it runs better, but eventually dies. After I go through this start, run, die cycle about 3 or 4 times (over the course of about 5 minutes) it will get going and keep running strong without further problems. I've done the following;
changed plugs
rebuilt carb
sanded down carb base on glass plate to make sure it isn't warped
replaced the carb base gasket, the leaf plate gasket, and the intake manifold gasket
reset the gap between the flywheel and the ignition module
cleaned the filter screen in the fuel tank
I'm getting pretty close to dropping this thing into the bay. Any help would be appreciated.
Dan
changed plugs
rebuilt carb
Dan
