Greetings
I have a bit of an issue that has me stumped ... I rebuilt both of my twin 1997 5.7L EFI - TBI Mercruisers over the winter. One engine runs like a dream. The other not so much ... I am having an issue with the EFI injecting way too much fuel which has led to plug fouling, black smoke in exhaust with a gas smell and a loss of power under load. Other engine has no issues at all. I have listed the items that I have replaced thinking that it was a fuel pressure or sensor issue messing with the ECM. I have swapped parts from the good running engine to troubleshoot. I have noted those items below. I am at a loss here since I figured both engines would be running well after the rebuilds.
Compression has been checked all cylinders 175PSI +/- 3PSI
Valve Lash adjustment re-checked
Any help is appreciated. Thanks!
Will
Components Replaced with new
fuel pressure regulator
throttle position sensor
map sensor
distributor cap/rotor
spark plugs
engine coolant temp sensor
Components swapped from good engine
Distributor
Ignition Coil
ECM
Will
map sensor
spark plugs
Distributor
Ignition Coil
ECM
