Need to remove a failed oil pressure sending unit on my starboard Chrysler 360. I confirmed it was bad by wiring the starboard gauge to the port engine sender. The sender is located at the back of the engine, down low between the distributor and the panel that makes the starter and battery connections and I can only get a grip on the top 3/4-inch or so of the sender, not enough to be able to break it loose or to able to get a wrench on it. Is there a tool (perhaps like a very small oil filter strap wrench) that will fit around the sender, which is only about two inches across?
These engines are mounted flywheel forward on v-drives and the back of the engines are actually partially under the cockpit deck, making this a very difficult place to work. If I have to, I'll move everything so I can get at the sender but that will make a 15-minute job into a two hour one. I'd appreciate any ideas
Bill
Bill
