Good day guys, I just received a 30 hp Mariner, 2 cylinder one carb, serial number 30 ML 689 L 331200 that was submerged 5 years ago, and yesterday I got it running.
Now, when the motor ran (actually it raced) the water coming out of the tell tale hole was hot (atfirst cold) and the water coming out of the tell tale hole was between a steady stream and a trickle (i.e. not a strong stream).
Also while running, the thermostat/exaust/close to spark plug holes were hot to the touch after 20 seconds of running. So, I shut it off. When trying to take a look at the stat, I twisted off (quite freely actually) one out of the 3 thermostat bolts. When running I noticed the area around the thermostat getting wet (i.e. dripping water).
My questions are;
-Could I have opened the seal somewhat when the bolt sheard?
-Does it sound like the thermostat is bad? If so, should I still try and take off the cover to clean up the area/test thermostat?
-What should I do next?
Upfront thanks for any help, i'm stuck guys throw me a life saver ring!
All the best.
Robby
Robby
My questions are;
All the best.
Robby
Robby
