Is it possible to delay opening of Secondaries
rmm
Right now they seem to open ri
Right now they seem to open right around 3050 rpm. Someone menitoned to me you can delay when the secondaries open by changing a setting on the carb.
Is this possible and can anyone explain? Thanks
"Ayuh,.........
It'd be
"Ayuh,.........
It'd be awlful Nice to know what Model of Which Carb we're working on,.........."
"OK sorry for the delay, the c
"OK sorry for the delay, the carbs are 1988 Rochester Quadrajets on Crusader 454."
"No problem. There's a li
"No problem. There's a linkage rod that pulls the secondaries open. You can mess with it to make them come in later, or remove the darn thing completely (as many people do. THe boat will plane off the same or better on the primaries alone.)
Gotta try all kinda tricks with that 4 buck a gallon gas coming our way.
Jeff"
Thanks Jeff. Also I bought th
Thanks Jeff. Also I bought the boat two years ago and don't know the maintenance history. What are signs that I should consider a carburatuer rebuild?
