"I am looking at changing out
"I am looking at changing out the impeller and anything else that looks worn in the outdrive water pump in my 5.0L Mercruiser this off-season. It overheats at 3000+, and the impeller's never been changed since 2000 (!). I am also going to pull the elbows and inspect/replace, since rust is showing at the spot where the starboard elbow meets the manifold. SHould I keep going and pull the manifolds, or will I be able to see pretty much if they're blocked up without pulling them?
Any tips/tricks/ things to watch out for on the impeller job? I'm a fairly accomplished shade tree mechanic, and I have a good set of tools, but I'm new to boats."
