urbanrenewal
Honda 150 hp and I have false intermittent overheat alarms happening. They occur with the thermostats out and with the thermostats in the engine. Pee stream is strong, temps read on the metal of the T Stat housings is well below “hot” (123 / 135 degrees). The alarm is continuous and the only light lit is the water temp light. Here’s what happens.
Start the engine. Engine runs fine for about a minute and alarm goes off, engine goes into safe mode. Shut off engine, immediately restart, runs fine for a minute or so, alarm goes off, etc. Immediately restart, engine runs fine, no alarms. Sometimes it runs fine after the first restart. SOmetimes it requires 3 or 4 restarts before running fine. Most of the time it runs fine without any alarms or messing with restarts.
I’m thinking bad sensor? Anyone else dealt with this problem in the past? Is there a way to test the individual sensors or do I need to have my dealer read codes? Engine is still in warranty.
Thnaks, Tom
Thnaks, Tom
