"J.... I've never run acro
"J.... I've never run across a Battery Capacitance Discharge system (which is what yours is called) having a intermitent ignition problem due to the powerpack. Those type packs were always either good or bad. They did have a habit of failing completely, staying that way for a hour or so, then coming back to life.... finally failing for good later on, but never being the cause of a intermitent spark problem.
I know that engine calls for Champion L77V spark plugs, but they have no heat range at all being surface gap plugs. I would suggest trying either Champion L77J4 or L77JC4 s/plugs and set the gap at .030. The difference between the two is the "C" which indicates a copper electrode which is supposed to last longer.
Check the continuity of the coil with an ohm meter from the rubber boot connector to ground, and from the rubber boot to the small coil wire that leads to the p/pack (I believe it's a blue wire). You should get a reading there of some king. If you do not get a reading, usually it is because the spring terminal inside the boot has lost contact with the inner wire of that coil lead. That in itself will cause a intermitent spark problem.
One other thing, and the flywheel will require removing to check it... If the "Reverse Cutout Spring" that rides the crankshaft right at the base of the timer base loses lubrication, the entire distributor cap and rotor will become incased with what looks like a "Black Powder" and that will cause all kinds of ignition interference. The cure is to clean everything, and if that reverse cutout spring is worn, replace it.... and lubricate it with what OMC calls Type D lubricant. I'd strongly suspect that you could get by with any high speed grease such as what's used in generators etc. If you can find the type D fine, but if not, use the high speed lube.
Note the flywheel must be torqued to 105 foot pounds. Make sure the flywheel key is installed with the straight edge vertical, not aligned with the c/s taper. Let us know what you find.
Joe
