intermittent electrical problem ???????????
boogerp1
i have a 1994 40hp johnson that will sometimes only run at half speed. i replaced the fuel pump with out the vro unit, replaced power pack,new spark plugs, is getting fuel.can anyone help????
Pull one spark plug wire at a time when the prob occurs and see which cyl is dead. This will give you some place to start.
Check for bent prop. may be overrev limiter.
try running at 2/3 throttle to see if cuts back.
Had this problem one time and dealer showed me
that as I watched, only changed prop and cured the trouble.
