Jeremy Jernegan
I have a problem when I turn the ignition key - the fuel pump activates and I hear a "click" from the engine compartment but the engine doesn't crank. I am suspecting the so called "Ignition system relay" - a small plastic cube on th ewiring harness in the engine. Batteries are good and starter and solenoid are fine and will operate when jumped. When it operates it is fine but at least every other time it does not do more than click.
Any ideas? Might I just replace the relay?
Jeremy
Jeremy
