Intermitent alarm88 150 Blackmax
gsmith131
"Hi,I have a 150 blackmax with
"Hi,I have a 150 blackmax with alarm going off at around 3000 rpms but goes off at 2000 rpms.alarm is intermitent which should mean low oil.Temperature is reading fine,new water pump and 2 new thermostats.could there be a blockage in oil pump or would it be a sensor issue.both remote and primary oil tanks are full and the main float seems to be working.any help would be great."
The gears might be failing. Ge
The gears might be failing. Get some mixed gas in there until you find out what is wrong. You can see the gears if you take off the pump and take out the shaft.
