"Happy new year Morten and res
"Happy new year Morten and rest of the forum participants. Yes I am still lurking around but I am too busy during the week to participate.
Cameron, I have already responded to your question in another thread about obtaining an AQ120. If your current engine is NG, I think your best option is to buy a suitable automotive block and marinize it. If you decide to go that way, I can guide you through the process. However, I also think that Morten is right when he suggests that you change the belt and timing gears, and I advise you to explore that option; it does not make sense to me that none of the cylinders have any compression unless the crankshaft has split by number 1 crank throw or the timing belt has slipped (or a totally ruined head gasket, which is highly unlikely). You can buy a set of used timing gears from a car wrecker and a new timing belt from your friendly neighbourhood autoparts store for a total of around $150; and if you want to do the job yourself, you should also buy either the Seloc or Clymer manual, which will guide you to the process. In fact, you should buy one of these two manuals (or both) if you own a pleasure boat with a Volvo engine and outdrive.
Stan, are you still fighting with your engine? Boy, that’s taking a long time. Anyway, I assume that you did not change the belt tensioner, which tells me that the slackness you are experiencing could be due to the spring being weak or sticking in the same spot after years of not moving. No, there is no further adjustment to be done, as the spring in the belt tensioner should compensate for any stretching that the belt may experience. However, as Morten very well said, you can always see a bit of slackness at higher RPM on the timing belt, especially while accelerating."
