Intake hose gasket
They're pretty cheap. Just
They're pretty cheap. Just make sure you get the right one.
You can also make your own.
... get a piece of rubber that's as thick as the gasket your replacing and bigger than the hose connector. trace the hose connector. cut out with a razor blade or similar device. turn it over and insert the razor in the middle and run it around the inner wall until you cut out the middle for the water to pass through. you're done.
oh. sorry about that. I erased
oh. sorry about that. I erased my first post because I wasnt sure if I had researched enough. I have an aq130c/270 drive. 1st boat. I was thinking of making my own gasket but I wasnt sure of the material. I thought it was a special gasket material.
Its not made of anything speci
Its not made of anything special. Just rubber to provide a seal between the hose connector and the drive.
"I finally changed the gasket.
"I finally changed the gasket. Well the water still doesnt exit like it did before, but then again. the carbs were dirty before and now they are not. also I ran the engine for a bit and it didnt over heat."
