carl_olson
Hey Everyone,
I'm working on re-sealing the lower unit on my 1989 Johnson 110hp VRO V4 J110TLAEM. I keep getting mixed instructions and I can't seem to find a consensus, so I'm hoping someone here can help me out.
- When installing the prop shaft seals into the bearing housing should I be using grease, gasket sealing compound, or nothing?
- If I'm supposed to use a gasket sealing compound would Permatex High Tack Gasket Sealant work?
- Do I use the same thing for the large O-ring for the outside of the bearing housing?
Somewhat off topic but does anyone know the torque spec for the 4 bolts used to hold the bearing housing?
Thanks in advance for any clarity you may provide!!
