Hi all, A couple months back my genny bogged during an overnight excursion, water in the port fuel tank was the culprit.
Replaced the standard gaso/water separator filter and sucked the culprit out from both tanks. Lucky for me that night it did not bogg the engines instead.
To prevent future misadventure of the same nature I'm considering a Racor "RAC320R-RAC-02" (metal bowl with drain plug) installation
to protect the twin 2004 merc 350 mpi mag horizon. I could buy the Racor and simply replace the standard merc stock spin-on canister, unfortunately
the stock canister is so low to the bilge floor that the Racor (with the bowl) just couldn't fit.
My alternative is to install the Racor as an additional filter to the stock one, but with some worries :
1) It's redundant with 2 filters in a line.
2) Engine room is rather cramp and the genny in its soundproof box sit right in the middle of the wall obstructing the fuel hoses coming from the tanks,
I would have no choice but to divert the Racor installation 2 feet to the port side, thus In/Out 4 extra feet hose line.
Briefly, the schema looks like this: Fuel tank--->On/Off valve---->"Racor (extra 4 feet line)"---->Fuel pump---->Stock canister--->Injector
Will this schema works? Is the fuel pump strong enough to deal with an extra filter and extra hose line?
Appreciate your advices
