Install of pertronix
tjwc1
Just wondering if anyone has a
Just wondering if anyone has a good detailed installmanual for adding a pertornix.. mainly looking for a timing proceedure after installing it
thanks tj
"But you should run a gnd wire
"But you should run a gnd wire to distributor, first. The gnd comes through the bolt and if bolt is loose, setting timing is hard."
"Brian, with respect I must sa
"Brian, with respect I must say I've never seen a case when you need to run a ground wire to the distributor. Even with the bolt loose, there is sufficient metal from the distributor in contact with the engine to provide sufficient ground."
