1981 proline
Hi everyone. I just got done replacing my water pump kit on my 90HP Eninrude. Unfortunately I had to cut my drifting rod in half to drop lower unit. I broke head off of linkage pin trying to unscrew. Luckily Marine Engine.com had two in stock. My engine isn't shifting correctly. I can't even get it in forward. My guess from reading some other post is that I screwed in shaft to far. I did it till it stopped. Can someone tell me what the distance is from gear case to the hole at the top of shaft is. I guess you check this in neutral?
Thank you for your help
