Inline fuel filter
jeff6898
I am gonna install a in-line f
I am gonna install a in-line fuel filter on my boat. Does it go between the tank and the bulb or the bulb and the motor?
If it is a thing that you will
If it is a thing that you will need to bleed then after the bulb so you can pump fuel in using the bulb. Otherwise if its just a little throwaway inline thing I cant see that it will make a jot of difference.
put it where it wont get stepp
put it where it wont get stepped on and where you can see it from setting at the wheel....i have mine before the bulb but i dont know if that is better..
"any filter is better than non
"any filter is better than none,try a water seperator ,not too much money and with todays
fuels would be worth it."
