Information on Mercury 135hp needed
alrae
I have inherited a 17ft boat w
I have inherited a 17ft boat with a 135hp Mercury outboard. Serial number OD107314. I am trying to find out what year this outboard is any any other relevant information about the outboard. It also has a Black Max label on the cowling.Is this to do with the model or is it the type of prop. Have done some research but nothing comes up for the serial number. Much appreciated for any assistance. By the way first timer on a forum. Thank you
"Alf, You may look up the yea
"Alf, You may look up the year at the www.maxrules.com website. Your motor is close in serial num to my 135HP Merc (1993). The BlackMax name is a name Mercury used for a while.
BTW - That motor is a typical V6 Merc. It has three two barrel carbs, standard ADI Ignition and a 40A charging system, and uses standard props. You need to determine if you have the 4-1/4 gearcase or the 4-3/4 gearcase, in order to know what type of prop to buy. The small gearcase (4-1/4) shares props with the 4/6 cylinder inline outboard motors. The large gearcase shares props with the mercruiser Alpha I and other V6 outboards"
"Thanks,Graham, Chris. Now i c
"Thanks,Graham, Chris. Now i can get the correct service book. Once i get the mecahical steering freed, the engine serviced, some gel coat repairs and some other other minor repairs, all I can say then is "snapper watch out here I come" Once again thanks"
