The electric fuel pump that was used to replace the Vapor Separator Tank (VST) is a Walbro GSL395. It’s an automotive part and I don’t think it can replicate the function of the VST fuel pump. Here’s why: I did the high-pressure fuel pump test per the service manual. Key on, the electric pump runs for two seconds and the test gauge indicates 30psi, which is right on spec. The pump shuts off, and the pressure is supposed to hold, but in my boat, the gauge immediately drops to zero. Then I did the fuel pressure regulator leak down test, plumbing a fuel shut off into the fuel return line and applying 12V to the pump. The gauge shot up to 60psi, which is right on spec, and held, which is exactly what it’s supposed to do. So, does the VST have some kind of check valve to hold the initial pressure from the 2-sec pump operation? Is that functionality missing from the Walbro pump? If so, I’m screwed, because there is no part number other than the VST, which, while I said I found one earlier, is actually no longer available. The pump that goes in the VST is available for $725, but you gotta have the rest of the assembly for it to work. Lastly, I took the boat out today, and with my buddy driving, saw that the test gauge on the high-pressure pump held 30psi steady at all throttle settings, and the gauge on the mechanical pump rattled between 4-5psi at anything above 2000rpm. Took the test gauges off, and ran the boat. The surging is still there, but not as pronounced, and the boat still only tops out around 36mph, and the tach goes wonky when I try WOT, so I’m not even sure how high the boat is revving. None of my buddies or I ski faster than 30, and I drove it around the lake a few times at 30 and it was OK. Not perfect, but OK. I guess I could replace the electric fuel pump with a new one and see if that improves anything. That would only be $135. Or convert the TBI to carburetor. That would cost probably $1k. That said, there’s a new anti-siphon valve on the fuel tank, a new Tygon sight tube running from the mechanical fuel pump to the flame arrestor, USCG Type 1A fuel line throughout and new stainless-steel hose clamps at all unions.
