"2000 Bayliner 2150 5.0 2bbl a
"2000 Bayliner 2150 5.0 2bbl alpha-1 gen-2 standard rotation.The shaft seal does not get inserted into the pump housing cover but stays 5/16 off the cover,is that correct? And am I correct in the vane direction if I soap it,put the cover on and turn the cover c/w to set vane direction(looking down at the outdrive from above when removed)?"
