I want to change my impellers. I have 1984 454's Crusaders 350hp.
can you give me instructions on where they are located ??
thanks everyone.
Why would a person not remove the four screws and the back plate to access and remove the impeller?
Not a dumb question at all!Sorry for what may seem like a dumb question SO: I see where the connection is to the crank but what holds the pump body in place properly ? Is that a bracket tab on the side by the hose connection? Thanks
several good reasons. Inspection of the other pump parts would be very difficult. Also, the cover holds the rear bearing to the shaft, so it will stress the system to force the cover on/off. The bearing here is graphite, brittle. Third, the bracket may make the 4 screw removal very difficult, as it has a rear plate that interferes. Sorry, for these engines, take the pump off and head for the bench.
