[COLOR=rgba(0, 0, 0, 0.701961)]I am replacing the water pump on a 85 Johnson 15 hp outboard. On the replacement part, The hole in the impeller housing cup for the drive shaft appears to be off center thus making the impeller off center in the housing cup. Is it supposed to be off centered a bit or should everything be centered in the cup as I would expect? Thanks for the help. -Gareth[/COLOR]
