Impeller or pump kitadvice 856X4L
dave_kirk
"Hello all, should i change th
"Hello all, should i change the whole water pump set up or just the impeller? would like to save a few bucks but not at the expense of gasgets, corrodid plate etc..etc.. is it that much more work to do the whole water pump set up?
kit = 85
impeller = 15
sleeping better = priceless"
"you kinda said it allready, i
"you kinda said it allready, if the housing is pitted/corroded then replace. run your fingers around it to make sure it is smooth."
"I'm with Brian - I change
"I'm with Brian - I change my impellers every second year and the whole kit every second impeller change (4 year intervals) - that gives lot's of heads up to find a kit on ebay at a price that doesn't deplete the wallet
"Thanks, is their anything tri
"Thanks, is their anything tricky about putting in a new pump kit? i've heard the hardest part is lining up the splines onto the drive shaft, is that a two person job??"
"2 people is easier especially
"2 people is easier especially if it is your first time doing it, one can lift the lower unit back on and the other can feed it up and bolt it on. When putting in the new impeller, make sure you only turn the shaft clockwise. you don't want the splines on the impeller going the wrong way."
i replace the the housing and
i replace the the housing and impeller evry year for all my customers
makes me sleep better at night
