impeller installation ?
You do not put the impeller in the housing !!--------Install the impeller on the shaft, then verify that the key is driving it.--------Lower the housing onto the impeller and while rotating the driveshaft ( the way the motor turns it ) and gently push down on the housing.-----Then you will say " that was easy "
cool thanks for the info. as for the shift cables what is the best way to make sure they dont get damaged when i remove lower unit and reinstall it
