Impeller change
Boldon lad 78
Hi, I have recently changed my first impeller on my 55hp engine, however on firing my engine up it is again pumping water through the tell tail but also is passing water through the hole used for separating the bottom end of the engine from the too, this is a small hole on the stern side of the engine!! I am unsure if this should happen or have I done something wrong?? Regards
