Hi All, As I stated before I'm new to outboards, I got my engine to start finally and now it isn,t streaming water through the water pump check hole. The engine is a 4hp (E4RDHCUD) I pulled the gear case but the drive shaft pulled through water pump and stayed in the power head. The impeller has one cracked fin so it needs replaced. My question is how do I get the drive shaft loose from the power head?
