luhrs_40
89 crusader 454 port side every 100 hours or so the timing advances it selve
without the distributor bolt been loose
From 10 deg to around 16
i use the boat as a charter and put around 300 hours per season
I checked the weights and springs in the prestolite distributor and seem ok
Can it be the gears on the distributor worn out? timing chain loose ?
engine has over 4000 hours but runs great good compression and dont use any oil
