1968chrysler35
"I want to verify that the ign
"I want to verify that the ignition timing is correct on my 1968 Chrsler 35. It has the old magento ignition (contact points and condensor - no alternator)
The manual says you have to use a special tool, (which I don't have) that's screwed into the top plug. You put the top cylinder at TDC and then back it off according the tool. Then you adjust the linkage using a light to determine when the contacts are open and closed.
My question is: Is there another way to check the timing without using the tool ? There are no timing marks on the flywheel so you can't use a timing light...
Ideas/suggestions....
Anybody have the special tool that they could sell or lend me.
Thanks,"
Thanks,"
