My 1987 Crusader 454 engines were working great BEFORE I tried to tune them up. I only replaced the plugs, caps and rotors ( have prestolite electronic ignition) and when I checked the timing, the light was finding the timing mark about 2 " away from the 10 deg Btdc mark. I adjusted the timing to be 10 deg btdc, and ran the boat. Smooth as silk up to about 2400 rpm and then it started to choke out as if the timing wasn't advancing.
Question 1: How could I have an initial reading from the timing light be so far off when the boat ran well previously ?
All wires are in the correct spot in the dist. cap. I am using wire # 1, 750 rpm. Plugs are all set to the correct gap. And when I replaced the old cap and rotor, I saw no change. I even tried using a different timing light with no change.
Question 2: If I can't resolve the first question how do I get my engines back to the correct timing ( where they were before) ? I have no marks to reference against. I have been doing this work onthese engines for 20 years and have never experienced this before. And I'm seeing the same effect on both engines
THANKS FOR ANY HELP !
