"I have a 1961 johnson 75 hors
"I have a 1961 johnson 75 horse motor with magneto style igniton. It does not want to start. I went throught the test procedures as follows. First disconnect the wire from the igniton switch and check for spark. I did this, no spark. Second rig up a wire from the contact surface of the coil to tester, (in this case it is a tester I made out of nails and a board with about 5/16 inch gap between the nails.) I then checked for spark and got the blue "snappy" spark that is described in the service manual. That lead me to believe, according to the info on this site, that the rotor button is my culprit. I was just wondering whether there could be another problem, such as the contact spring inside the distributor cap, or the wiring from the points assembly to the "lug" that the ignition switch wire connects to, that I need to check before spending money on the rotor? What other test procedures can be done. I have checed the "lug" where the ignition switch wire is connected with a test light and I get a very small amount of voltage there while cranking. Is this normal? Also can anyone tell me where i can get a cap and rotor for this. Keep up the good work.Your site is more informative than the service manual is. thx
