Ignition Switch Wiring 1974 115hp
nightrain
Hi,i write you from Italy,i'm trying to rebuild my 17" aquasport,i've got a 1974 115cc johnson,someone of you knows which are the color and when i hav to connect to the Ignition Switch Wiring??????
Re: Ignition Switch Wiring
yes,...prob would be easier,if u listed the wires,but off the top of my head--
red--batt
yell/red-start
purp/wht-choke
blk/yell-- raised 'm'
blk--m
tan--overheat
purp--acc's/overheat horn
grey---tach
i've got 8 wires,1-white,2-red with violet stripes,3-black,4-black with yellow stripes,5-grey,6-brown,7-violet,8-violet with white stripes,but i have 5 position on my Ignition Switch Wiring,how do they connect???thank's for all :)
You need a ignition switch with six (6) terminals indicated by JWB as follows:
M - Has a raised tower like terminal = Black/Yellow (powerpack)
M - Regular type terminal = Black (ground)
B - Red/Violet (Actually is Red/Purple) (battery voltage)
S - White (starter solenoid)
C - Violet/White (Actually is Purple/White)
A - Violet (Actually is Purple)
Brown (Actually TAN) = Warning horn terminal closest to built in horn ground wire.
Gray = To tachometer sensor terminal
That's correct, I did. Apparently you didn't see the very first line of my previous reply.
What are the five terminals on your switch marked.
The missing terminal on your igniion switch is the "C" (choke) terminal. If you have a separate choke switch, the Violet/White would connect to one of the choke switch terminals...... with the other choke switch terminal having a wire connecting to the "A" terminal of the ignition switch.
All of the other wires would connect to the ignition switch as previously posted above.
