ignition switch 28hp
The ignition switch relates to the control box, tiller handle or the switch panel that it fits. What is the application?
You can got to yamahaoutboards.com and view the Yamaha parts catalog and see all of the switches that are used.
Then, get what you need from a Yamaha dealer.
Red is 12v
yellow is ignition
brown is start
white is stop
black is ground
green is tach
blue is gauge and lights for gauges
Sorry, I thought you were looking for a switch. In a Yamaha the switches are normally plug and play. But, if you are wiring one up from scratch then refer to the illustration below.
There are five colors to be concerned with.
Red is 12 volt positive battery power TO the switch
Black is the ground
Yellow is key ON power FROM the switch TO the motor when the key is in the start or ON position
White is the kill switch wire TO the motor that applies the ground to the CDI to stop the motor from running when the switch is in the OFF position
Brown is 12 volt positive power TO the starter motor when the key is in the START position
