My Merc 170 quit starting, I can jump start it at the solenoid and I can jump start it at the ign. sw. with the red and yel/rd wire lifted. ( The engine is just turning over not running. This tells me the start wiring is good thru the neutral safety sw. to the solenoid.) When I replace the wires on the switch, I get nothing.....when I lift the purple run wire off the sw. the engine will turn over with the key? when i replace the purple wire on the sw. I get nothing...could the purple wire be grounded some where?? It has an electric choke on the engine...stuck in dry dock..Thanks for the help P.S. I rang out the sw. and it's good.
