I have a 440 c.I. chysler 1973. I can not get it above 2500rpm, it starts up great, idles ok. When its not under load rpm will run up ok, but under a load it will not go above 2500 rpm. it also does not miss on the way up to 2500 rpm. it has newer Eldebrock carbs. A few years ago I installed a Mallory dist. I checked out module ( according to Mallory instructions it checked out 1 .3 volts. Also timing is spot on. Any help greatly appreciated. Thanks
