"Engine won't start. Prima
"Engine won't start. Primary coil test passed - key to run position, move points, coil wire 1/4" from ground gives good spark. Crank engine - no spark. Could this be bad points and condenser? Voltage at + coil is 12.1 volts. Voltage at + coil during crank is 10.9 volts. Plenty of gas, 5 to 7 second cranks and engine will flood. We bought used. Previous owner used whatever engine parts he could find to replace parts that went bad. Lot of Motorcraft parts. Any ideas why no spark during crank? Thanks. Doug."
